1979 MCM 260 5.7L 350cid
Serial# 5424302
I am getting inconsistencies with part numbers and replacement with the vendors, not sure if it's my mistake or theirs. Does it matter which style of solenoid this has? The one I am replacing has the posts that are in a over/under pattern and the one they are trying to replace it with has the four posts in a row.
It may also be pertinent to mention that I want to add in an electric fuel pump, if you look at the attachment you will see my plan to wire it in, not 100% sure if that's how I should do it. The manual has the purple with yellow going to the slave solenoid, I planned to wire it to the starter along with the new pump. Also, I want to switch this from an amp gauge to a volt gauge.
Ok scratch that I can't seem to up the pics I had ready so hopefully you can decode what I am trying to say without them.
Serial# 5424302
