Re: 1979 Mariner 80 hp Trigger & Stator Wires
Man I feel your pain. I went through the same thing. YES, you can splice onto the wiring.........IF you can cut it back far enough to get a good connection. Here is what I did, and it worked for me.
I purchased some good quality marine-grade wiring very close (in size) to the wiring on the trigger. I purchased it in WHITE. Then, I soldered the connections together, and I used a good quality heat shrink on the connections. Then, I actually colored the wiring with a Sharpie Magic Marker to keep things organized. Some people will say not to solder the connections, and some people will say not to bother trying to repair the wiring, but I can only say that it worked out good for me. Saved me some $$$$ for sure.
