78 MarkTwain
Thread starter- Joined
- Apr 10, 2012
- 15
I am looking at buying a 1979 Johnson 115 (115TL79R) with power tilt/trim that needs a new stator. I have a 1978 115 (115ML78C) without power tilt/trim with a working stator and timer base. I am noticing that motors from these year used a 6 amp stator if there was no tilt/trim and a 10 amp if it had tilt/trim. My question is could you run a 6 amp on the 1979 with tilt/trim and be ok? Is there a difference in the rest of the electronics or just the stator?
thanks
thanks
