1979 Johnson 9.9 Help!
hoytshooter25
Hi guys, I joined a while back after picking up a 1979 Johnson 9.9 and I am just getting around to getting it going. This motor was sitting for the better part of 10+ years outside but partially covered. When I first picked it up it would fire and run for a few seconds on starting fluid. After getting a new gas tank, impeller, installing a carb kit, and putting a new spark plug in I can't even get it to fire. This is really my first outboard but I have a pretty good mechanical knowledge and skills. I am wondering if there is something that is more likely the culprit here that I should start with or what/how should I test? I know it says "MAGFLASH" on the cover and the model is 10R79B. Any help or suggestions would be greatly appreciated.
flyingscott
Did you hook the choke up when you put the carb on. Did you clean the carb completely and why only one plug. Put up a pic of the motor preferably the powerhead. stop using starting fluid and what is the compression.
hoytshooter25
I believe I did have the choke hooked up, how would that effect spark? I guess i should have said better that I think that problem is lack of spark. I did clean the carb completely and I meant "plugs", just a typo. I have not checked compression because I do not have a compression tester as of now. It was a good running motor from someone I know, it has just sat for years because they didn't have time to fish anymore. I am having trouble with pics, I keep getting an "invalid file" error message, is there a size limit or something on pictures?
hoytshooter25
See pictures...
the machinist
You need BOTH properly timed spark AND fuel for it to start/run. Those old motors can get a lot of slack in the throttle linkage gears & IF it is set so SLOW that you are getting very little fuel into the engine, it will be hard starting. However if you advance the throttle faster may help as you can always slow it down after it starts. If the choke rod is placed in upside down, the choke will not work effectley.
Did you pull the small aluminum soft plug on the top of the carb & be sure the passages were clear by blowing compressed air thru them ? What about doing the same for the lead shot blocking the corners on the other drilled air passage holes?
hoytshooter25
I did not go quite that far with the carb. I realize you need the properly timed spark and fuel to run but I am not seeing spark at all, regardless of the timing. That is why I thought to try to figure that out first. Any thoughts on where to start first or how/what to check for spark issues?
flyingscott
Get a spark checker and double check your spark you need it to jump at least 7/16" inch. Did you do a link and sync
Honorary Supreme Mariner
Sneak into the workshop at night.----Lay plugs on the block.---Turn lights off and pull the cord. --Look for spark.----Not really a good test but it is visible in the dark if there is spark.
AlTn
at a minimum you have a questionable ground on the lower coil...suggest you remove both coils and clean ( sand ) the mounting points for the coil ground wires..unplug the amphenol connections and use some rubbing alcohol to clean the male and female connection ends, disconnect the powerrpack and clean its ground wire connection and ends...after doing this do you have a spark on either cylinder?
