1979 Johnson 55 Starting without control box
colewhitmore41
I have a 1979 Johnson 55 Horsepower that I bought and it came with controls but i soon learned that the internal wiring harness was corroded and no power was getting through many of the wires. Before I spend a lot of money on a new harness and other things I want to check the compression. I tried hooking up jumper wires from the battery to the negative ground on the block and then putting the positive end on the bolt on the starter where the wire comes from the solenoid is and the starter spins fast but it doesnt engage the flywheel. It looks like it is spinning the opposite direction that it needs to in order to engage? Is there something else I can do in order to turn the motor over without using the control box
F_R
Honorary Supreme Mariner
What you are doing is right. Your cables are bad, or your connections are bad, or your battery is bad, or your starter is bad. Instant acceleration of the starter (inertia) is what makes the gear rise. If your polarity is correct, it is impossible for it to spin backwards. Should spin counter-clockwise, looking down from the top.
Disconnect the alternator before doing all this. It is possible to blow the rectifier if you don't.
