colewhitmore41
Thread starter- Joined
- Aug 13, 2016
- 6
I have a 1979 Johnson 55 that will run great and will rev up to Rpm in gear while on muffs but it acts like it has no power when I open it up in gear on the lake. I have cleaned carbs recently and the fuel is new. The motor doesn't sound bad when it's running sluggish at wot it just has no power. No sputters or bogging sounds. The engine noise sounds fine it just never gets up to rpm. When I changed the water pump recently I forgot to put back in the squarish metal tube that pushes into a gasket next to the water pump that I'm assuming is for exhaust, could this cause an issue like this or is it something else? The prop is pretty chipped up and broken but I thought I would've atleast gotten some better rpm and power even with a bad prop
