1979 Johnson 35HP - Lower untit oil and grease
bigdee2
I want to service this motor - I was told there is a lower unit oil to be checked and changed and also lower a special lower unit grease to be filled after removing any metal shavings? Any help is appreciated. Thank you.
Honorary Supreme Mariner
The lower unit is filled with outboard gear oil.------NOT GREASE.-----Take the time to visit ---you tube----There are numerous videos on how to do this job.------It is such an easy job , that it can and has been done wrong !---Search for ---outboard gear oil change---and look at some of these tutorials.
