Re: 1979 Johnson 115 throttle lever
Popr367.... If you're saying that the vertical throttle lever moves as it should when you apply the throttle, but the timer base under the flywheel does not, then the timer base assy is sticking.<br /><br />When the timer base sticks, that would cause the timing to be retarded in relation to the throttle setting which could, and usually does, result in having the engine die out.<br /><br />The sticking of the timer base could be caused by someone at one time applying grease to the nylon retainer bearing support which would collect dirt. Another cause could be a leaking failing stator assy which would cause a sticky substance to drip down on that nylon bearing area.<br /><br />The cure is to remove the timer base and clean it along with the nylon retainer. Upon installing the assy, use only oil on the nylon retainer, and a small amount of anti corrosive grease on the inner brass bearing portion of the timer base and related surface of the top crankcase head surface.<br /><br />Be sure to torque the flywheel nut to exactly 105 foot pounds. Any less will result in a sheared flywheel key.
