The motor is on a 17 fiberglass tri-hull, starts and idles fine but when I put the boat in the water. The motor comes up to about 2000 RPM or about 6 MPH at full throttle. The motor runs great at this speed, but will not run at full throttle. I have replaced the fuel system up to the carbs and the spark plugs..
The second problem. When I got the motor it would shift into forward just fine, but when placed in reverse there was no reverse. I replaced the shift linkage connect below the carburtors, now it goes into reverse, When in reverse it trys to jump out of gear. Is this an adjustment problem or a problem in the lower unit? If it's the lower unit, do I need any special tools to disassemble the lower unit?
This is my first time working on an outboard motor,
