FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I have a 1979 johnson 15h outboard. I am getting water into the gearcase. I replaced the water pump and seals below pump. Problem appears to be seal on shift rod going int lower unit. How do i get the shifr rod out.
I changed the seals under the water pump. When i did pressure test, I saw air bubbles coming from shifter seal. May find more after i close this up. Thanks!
