1979 evinrude 85 hp carburetors
antonio88
hello i have a 1979 evinrude 85 hp but one of my friends gave me a 1973 evinrude 115 hp i was just thinking wat makes the 115 hp bigger than the 85 hp i know the horse power, so my question is if i put the 115 hp carburetor on my 85 hp it will encrease power or wats the difference cuz they look kind the same
coolbri70
Re: 1979 evinrude 85 hp carburetors
they are different, at least the block is a different part, the 115 does share a case with the 100
antonio88
yes i saw that, so changing the carburetors wont do any change then? or they dnt do the same?
Honorary Supreme Mariner
You may find that the 85 / 90 HP blocks had smaller intake ports.
antonio88
so how come both carb kits have the same part num
boobie
The kits fit the different carbs 'cause they are the same externally but different internally. Throat size, jet size, and ect.
Faztbullet
The 85 has small exhaust ports and different port timing. The ports are 4 hole about the size of you ring finger. The 90's are larger and about the size of you middle finger and port eight is a little higher
emdsapmgr
You can use the 115 carbs on the 85. They have larger throats, so will move more air/fuel. Likely the 115 carbs may overfuel somewhat, so you may need to rejet them lower slightly. They will make more hp on that block once you get the carbs dialed in. Both blocks are 99.6 cubic inchers.
On all the 85 / 90 HP blocks that I have the INTAKE ports in the cylinder are smaller than the 115 /140 HP blocks.
wayneo99
been there done that... the 79 85hp carbs are 1 inch bore and only have 2 jets.
the 115 has 1 3/16 or 5/16 and 3 jets.
both of thoses carbs i believe dont have the primer nipples and the engines dont have the recirculation system for fuel return.
IMO its not worth the hassle. run ti the way it was engineered
Intake ports , also called tranfer ports in the cylinder wall are smaller on the 85 / 90 HP blocks.
emdsapmgr
Both carbs have the conventional choke system, which is conveneint for a swap. The recirc system came later-83 and later. I run a set of older (1974) 135 carbs on my 1979 85 hp Johnson engine. It was ported during overhaul and initially overfueled with the 135 carbs (1 5/16" size), requiring a reduction in the main jet size. It really hauls the mail now..
