Theoutdoorsman
Thread starter- Joined
- Mar 6, 2003
- 681
Motor coughs at an idle and is sluggish when throttled up. It takes 10 times longer to plane than normal now and won't turn the usual rpm's at WOT. This is a problem that has progressively gotten worse. The carbs have been freshly rebuilt by a mechanic, fresh fuel in the tank, new water seperater installed, and all fuel line replaced. No change in performance, although the cough at an idle is almost non-existant now. When I bought this motor 1 1/2 yrs ago, it had been rebuilt by a mechanic and ran like an absolute dream the first year. Seldom ever at more than 4500 rpm's. A little history on the motor........On three seperate occasions, all at different times of the year, the motor died at WOT as if it were running out of fuel and ultimately shut down. Each time, it would not turn over until it cooled down for about 5 minutes. It wouldn't even try to turn over. It was almost as if the battery was dead. Once it turned and started, it ran fine. Then, it didn't do this again for two or three months. Same thing the other two times. Hmmmm........end of history. At any rate, I now have the above mentioned problem. Any suggestions on trouble shooting this? I REEEEAAAALLLYYY want my 140 back as I'm sure you guys understand!!!! This has really puzzled me. At first I thought maybe the pick-up in the fuel cell might be clogged, but now I'm not sure. A service manual, owners manual, and parts manual are all in-route to my house as I type. I'm kind of ignorant when it comes to motor repairs, so any and all help would certainly be appreciated. Thanks in advance.............ALAN
