truehybridx
Thread starter- Joined
- May 8, 2016
- 9
So the only real problem the boat came with is the spark advance / throttle levers would not return to stop when the control put into neutral (or the fast idle lever is pushed back down).
We ordered replacement control cables just because that was the next thing the previous owner was going to do and on the motor end when you push the advance/throttle lever to their low stop position there is about 1/3 to 1/2 an inch of play on the motor end of the throttle cable.
Was this a good call? Could that much slop be developed in a control cable over time?
I also ordered a replacement nylon bush for the inside of the control box because there is some wiggle on the pivot that attaches to the throttle cable at that end. Is there anything else I could be missing that would contribute to the slop? I'm kinda still in awe that there is no actual return spring for the advance/throttle in the event that the cable breaks.
Edit: I can't seem to upload pictures. Maybe linking them will work
https://www.dropbox.com/s/p3zphenmgq..._0233.JPG?dl=0
https://www.dropbox.com/s/jnutdfm51j9x2qo/IMG_0236.JPG?dl=0
