1979 evinrude 100 problem
jimmys3
hi there i have a 79 evinrude 100 hp outboard.it starts and runs great except sometimes it starts to cut in and out or basically the equilivent of pulling back on the throttle. it can happen right off the dock or 30 to 40 mins out but when it happens it won't completely stall but throttle makes no difference in any position. let it run on low speed a few minutes and open it up again and sometimes off it goes sometimes another few minutes is required.than off it goes again could be 5 minutes could be 30.things i have done so far carb kit, new plugs, including coils and wires (cause old ones were in bad shape with bad wires)changed water pump thermostats(just cause i didn't know when they were done last not to cure this problem),new gas tank hose fitting and all gas lines, and cleaned all grounds and checked for burnt frayed wires.compression check was good.the confusing part is it docent mater if its warm or cold i tried pumping fuel bulb when it was happening and it changes nothing.sorry for the long post just searched and found some with similar problems but no solutions have worked for me as of yet
DRCrowe
Mine did the same thing a few years back. Ended up having a bad power pack. Does yours have 2 power packs? Mine would run fine and then drop half of the engine and then come back again. Just a thought.
