New to me boat my first is a 1980 aquasport family fisherman with a 1979 100999s evinrude 100. Been running down an erratic miss found that the stator was only putting out 80v DVA compared to the 150 to 400 it's supposed to replaced that and two failed coil packs on 1 and 4. The rest of the cdi test out positive. I've cleaned and rebuilt the carbs floats and all. New fuel pump not the kit the whole pump the old one was JB welded with a pipette to hold it together. New champion plugs gapped at .30. Link and sinked about 30 times now. Compression tested all 4 and all even at about 110 to 120. Set timing to 4 and advanced to 28. The issues I am stuck on right now is that I cannot get it to idle the only way it will is if I hold the timing linkage to full advace even after its warmed up no change. I checked the jets and they are right in spec so I'm just dead stopped for ideas. Any info or advice would greatly be appreciated. I really need help with this.
