1979 evenrude fuel fillter question
jaredcando
Hello i was wondering if a 1979 evenrude V4 100hp engine has a built in fuel filter on it. I was running the other day and it just started running rought 20 mins in, like it was not getting fuel and i was wondering if it has a filter that i can clean or replace i am new to boats so am not sure what to do. The plugs are new and it ran fine for 20 mins WOT at 38MPH at 5100 rpm which seems about right.
emdsapmgr
Re: 1979 evenrude fuel fillter question
That engine does have a type of fuel filter. It is under the round, black cap on the side of the fuel pump. It is a round screen. I've always added a Bombardier clear/whitish inline fuel filter to the fuel tank hose as an added precaution. They are cheap and work. You have the wrong pitch prop on that engine. The engine should run at or slightly over 5500 normally. You are lugging it at only 5100. Your hole shot and fuel economy will improve if you change props. The next lower pitch prop will add about 300 rpm to your engine. Keep in mind that weak ignition components tend to break down when the engine reaches normal operating temps. They work fine when cold, then don't when the engine warms up.
jaredcando
Thank you i planned on adding another filter just wondering that maybe this was the problem before i start removing carbs and stuff. I just bought the boat and it came with this prop which is brand new is it ok to run on this prop for a season and then purchase new one with the correct pitch next season. Thanks for your help.
emdsapmgr
You can run that prop. When you get the correct prop, you will find the engine much more responsive and your fuel economy will improve.
jaredcando
Thank you i appreciate your time. i have one last question. The boat is a 1979 and most of the stuff on it is quite old, and from what i have heard the new ethonal gas is horible for these older engines is this true and if so what can i do to prevent this damage.
emdsapmgr
A couple of things: 1. The original factory fuel hoses inside the 1979 cowling are not compatible with today's ethanol fuels. If you run ethanol blend gas through it, you may eventually find small black bits inside the jets of the carbs. (Small pcs of fuel hose.) A fuel restriction can run the engine lean-potentially a real problem. You can go to a Bombardier dealer and buy all the same fuel hose part numbers again. The new hoses will be compliant with 2011 fuels. (Those internal hoses that have part numbers assigned are heat formed so that they maintain the hose diameter when bent to a 90 degree corner.) 2. There was a 1986 OMC service bulletin 2159 that talked about the new fuels. At the time, new gas was first being produced with no lead at all. That became a concern for powerhead durability. The bulletin addressed the engine timing. If you ran with the normal 87/89 octane, that crossflow engine should have it's timing reduced by 4 degrees. If you chose to keep the timing at the high factory setting for performance, you could do so only if you ran 91 octane fuel. That's your call on how you want to handle that issue. Ethanol fuels are ok, if fresh. 3. If the fuel is 3 months old, it's probably ok. When I store over the winter (6 months,) I drain my tanks completely-then get fresh fuel in the Spring. If the fuel is over 6 months old, I would dispose of it-burn it in your car or other 4 stroke engine like a lawn tractor. The ethanol in the fuel attracts water over time and really old/stale fuels can go through a bad process called "phase separation"-when the ethanol separates from the fuel and settles to the bottom of the tank, along with the water. 4. A three year old Mercuy service bulletin states that their preference for long-term storage is to drain the fuel tanks completely-the opposite of earlier preferences to fill it for the winter. 5. Today's lead free fuels are harder on the crossflows-they tend to accumulate carbon around the ringsets more than when we had leaded fuels. Bombardier makes a product called Engine Tuner. You can give your engine an annual dose of this and it really works to keep carbon of the pistons/rings. If you think that decarb process takes too long, you can purchase their XD50 2 stroke oil-it has that carbon guard additive measured into it-which works as you operate the boat.
jaredcando
Ok thank you for all this info i have been running the engin with high octane fuel since i have owned it. And i have also purcahsed some sea foam additive that my neighboor side would help with the ethonol issue, but as soon as i use up my oil i will switch the the XD50. Thanks agine this site is really a excellent source of info.
