1979 Evenrude 200hp V6
memore
I have a boat motor that had a used lower end put on and before it went to mechanic's was running good until lower end went out. $900 later we have no power to go fast, we put a water/fuel seperator on and now it runs a little better, but now we have 3 spark plugs on the same side not firing. We assume this is out problem but cant figure out why, can anyone help with suggestions? Thanks :confused:
mikesea
Re: 1979 Evenrude 200hp V6
I would say your powerpack on that side is bad,you can swap with otherside to check,it connects to coils
memore
Thanks we will try that and let you know. Probably Fri before I get to work on it again.
memore
I swaped the powerpack and the fire changed sides is that the problem or gould it be something else? thanks. please help
memore
What could have knocked out the power pack to make it go bad? I dont want another one to go bad, thanks for all your help!!
83ebbtide
If its the original power pack it probably just failed. Over time heat can work electonics over and cause them to fail. May not be anything you did. You can check the wires to make sure they are getting a good ground and make sure the others are connect well.
emdsapmgr
While the power packs are generally pretty reliable, they probably have the highest failure rate of any ignition component.
