Panthers06232
Thread starter- Joined
- Apr 5, 2020
- 8
Just bought a skeeter bass boat with a johnson stinger 75hp. First test on the lake the motor starts up idles good put it in gear and go to take off you can here it surging does put the boat on plane but surges almost the entire time. Brought it home took carbs off noticed the airbox was barely bolted on really loose clean carbs put back together. Second water test starts runs good take off does the same surging/bogging but not nearly as bad bump choke helps a little bit. I also did notice the little clip that goes on the float to the needle not one of these carbs had one is that normal where should I go from here
