1979 70HP Johnson bogged down after using Seafoam...
1983 ercoa 21'
Sometimes we don't always get to see what's causing the problem .
the important thing is that it's working now.
good job!
oldboat1
god love ya marcusknight, but feel a snark coming on. "clean the carbs" means taking the carbs off the engine, actually taking them apart and cleaning them -- point at which most folks put in rebuild kits. Can't politely ask if a guy REALLY cleaned the carbs when he says he did -- as in took them off, took them apart. Actually cleaned them. Maybe need a forum requirement -- swearing-in session on carbs (special clause for multiple carbs on multiple carb motors)....
done with the screed. Glad your motor works -- really. Summer fun ain't over yet.
will be ok now. lemme alone. :smash:
Tim Frank
Unless there is more that you omitted (like more details on the performance issues that you were trying to solve) , you messed with the fuel system and now have a problem. The first thing I'd be doing is a full diagnostic on ....the fuel system. :)
If you have dislodged stuff with the SeaFoam, which makes perfect sense, in my experience you are not going to fix the problem with externally applied-sprays.
Worth a try I guess because even a slim chance would really pay off if you got lucky in time saved.
More likely you need to do a total clean on at least carbs 1 & 3...at which point it would be a false economy not to do #2 as well.
If you have nor replaced fuel lines in a few years, that is inexpensive and well worth the $ and time.
