I've got a 1979 evinrude 35hp tiller outboard pull start. I run nav lights, a fish finder and a stereo on my boat and wanted a charging coil. After looking on google, I thought I'd figured it out by ordering the charging coil kit seen here:
OMC Evinrude Johnson Battery Charge Kit 4 Amp 175271 25 35HP 2 Stroke 2 Cylind | eBay (if it will let me post the link?, kit model number was 175271 and included rectifier, coil, cables and fasteners. I hadn't been aware there was a difference in these components between later and newer 35's. Anyways, got the flywheel off. and the plate to mount the charging coil on is all wrong. My question now is: is there a way to make the kit for the newer omc outboard charging kit work on the 1979 by putting a newer plate ? or am I better off cutting my losses, using the rectifier from the kit (same model numbers) and try to find a 1979 stator PN 0581651 and is that all I would need?
Thanks,
Erik
Thanks,
Erik
