1979 35 hp. stalls
bob is mad
no power after 5min. run across lake. restarts good but no acceralition, If I hold key in to activate chock it runs about 50% better.Have replaced water pump and thermostate.
Bob_VT
Re: 1979 35 hp. stalls
Welcome to iboats.
You need to verify spark in both cylinder's ;) sounds as if you are only running on one and our ears normally do not detect a change.
boobie
You may also need some carb work if chokeing it helps.
