FISHBONE74
Thread starter- Joined
- May 2, 2008
- 19
I have a 1979 35 hp johnson that i have had fo almost 2 years and have not fixed the water pumping problem yet. When i turn the key on and the motor is cranking the water pump works great (steady stream of water) but as soon as it fires up and is running on its own the water instantly stops (just like closed a valve) I have replaced the impeller 3 times cup,gaskets made sure the water tube is inplace cleaned the tale tale hose nothing seems to fix the problem HELP!!!!!! ANY IDEALS
THANKS IN ADVANCE
THANKS IN ADVANCE
