Elmer G Wolochaty
Thread starter- Joined
- Oct 14, 2015
- 4
Over the years my 35 Johnson has been functioning well & recently testing out at 115 p.s.I. Recently I had a local dealer do a complete carb job on it and since then I've had the unit out 3 times with the following results. The first time the unit functioned just fine, but the next time it seemed to cough & sputter a lot, acting like it related to a gas flow problem. While in neutral at start up, it did not rev up freely but only stayed at a fast constant idle regardless of my actions at the control lever.When in gear, it still functioned on a limited basis and simply would not go to full throttle.
By assumption, after installing new spark plugs I tested the unit again with the same results, but then after going a little distance the unit would suddenly seem to catch and accelerate and function as it should normally. This kept on happening.
Based on my description, the shop feels that it is an indication of faulty power pac, but I am hesitant due to the age of the unit and the possibility of other costly issues at hand. I have never had this problem before and would appreciate any thoughts and advice at this time.
Thanks
Thanks
