'79Evinrude200
Thread starter- Joined
- Sep 15, 2009
- 3
I'm new to this forum and this is my first post. I have rebuilt a 1979 Evinrude 200 HP with pieces and parts from ebay and other sources. The boat starts right up and runs great (5250 RPMs), all day, no problems...except...
Problem number 1: There seems to be an extreme amount of unburnt fuel that dumps into the water at idle, at normal running RPMs and at OFF. What I mean is that even when the motor is turned off, unburned oil and fuel (as I pre-mix in the gas tank 50:1 (synthetic)) fills the water like an oil slick. It seems to be coming from the prop area? It is literally as if the Exon Valdez had just left the area. I've tried running a six gallon tank with non-synthetic to see if it was the oil, same results, however. No unburnt fuel under the cowling however; just exhausting out. FYI- I've got great compression on all 6.
Problem number 2: After a few hours of running (that's running, not starting, as the boat starts right up), the starter seems to actually overheat and won't start the boat. I am talking about for hours. It takes hours to cool it down. This is when I pull out my trusty back-up starter and carefully change them out with an oven mitt. The boat starts right up and off I go, slicking up the lake with my unburnt fuel problem.
Any help with either of these problems is greatly appreciated. Thanks...
