1979 150TL79C Johnson Outboard
GeeTee
hi Guys and Girls - been told to ask here because apparently ya`ll "know it all" ;-) I have a question re the above mentioned engine, i just boat a fix me upper and the engine/powerhead seems to be stuck/seized. The seller informed me that it ran a year ago after it was stored. I cannot move the motor by turning the flywheel, do i assume that the pistons may have rusted in the block? I have removed the spark plugs and it there is no rust on them, they are lubricated. How do i determine the extent of the damage or how do i troubleshoot that?
Second question, the cdi units were removed - how do i determine the firing order in order to put the cdi units back onto the motor, ie, is cylinder 1 top left if looking at the engine from the rear or would it be on the right hand side. I have been searching the internet for info but little to none is available.
Thanks in advance.
jakedaawg
Pull lower unit to see if engine is seized or lower unit is seized.
emdsapmgr
OMC is pretty proprietary about their service information. If you'd like to get an original factory manual (highly recommended) check out this website: outboardbooks.com. Their parts lists are online at: epc.brp.com
fishdady
Second that! Clymers and Seloc are to vague, cover to many years. Get the actual service manual for your engine. I've seen them on e-bay, fairly reasonable, too.
