James_Ketcham
Thread starter- Joined
- Jul 25, 2019
- 43
So i'm wiring up the engine to the boat which is a 1979 Mark Twain Vsonic and I notice a few issues. first being on the back of the tach has a selector 1 2 3 4, which i'm assuming is for the number of cyl of the engine. My 140 is a 6 cyl. So i'm looking at the factory service manual for the engine and it is showing the tach wire as being connected to one of the pulse wires on the rectifier. Now on the 1978 diagram ( engine wiring ) it shows the tach hooked up to the Brown connector on the switchbox. So i'm wondering do I set the tach for 1 cyl and hook it to the rectifier as the 1979 service manual says or leave the wire connected to the switchbox brown lead and set the switch on the tach for? Sorry if that sounds a confusing, but I don't want to burn up something. My engine has the trigger plate in the distributor if that helps. Under the flywheel it's just the charging stator with the 2 wires that run to the voltage regulator/rectifier. Any thoughts?
