1979 115hp Johnson weak sparks.
Valv
I have a 1979 Johnson 115hp V4. I started it yeasterday to decarb it. This morning after letting it soak overnight I cannot start it again. Funny thing spak plugs have weak spark, and if I attach all 4 (loose) to see if sparks occurs, they won't. I will go buy a spark tester tomorrow, but in meantime does anybody know what could cause 4 weak sparks ?<br /><br />Thanks.
rickdb1boat
Re: 1979 115hp Johnson weak sparks.
Did you install new plugs after the decarb?
12Footer
One thing would be a starter drawing too much current. <br />A bad battery, not supplying enough current, or corroded terminals on the battery,solenoid or ignition witch.<br />Try pulling it thru (with the plugs out), to see if you have a hotter spark.
D
DJ
Guest
Hey Valv,<br /><br />That decarb. chemical is VERY hard on spark plugs.<br /><br />Throw an old set in to see if it helps.
Valv
Yeah, I noticed is VERY hard on plugs, I tried older ones and a new set. I just went outside while is dark and try to start it. No way. I have 3 batteries I alternate, while I try. It has 120lbs even all 4 cylinders, carbs rebuilt this winter (I haven't used boat yet, you know MN, lots of cold...).<br />It really puzzles me since I started it yesterday, doing a decarb as per instructions from you guys, let is soak overninght to give a second decarb with just a couple of hours soak.<br />Not a sputter, choked, not choked, spray mix into throats, tilt up, tilt down, pull plugs, crank it in case it was flooded, new plugs.... :mad: <br />I will pull flywheel tomorrow and check if crankshaft did break key and threw timing out.
