sgtallen414
Thread starter- Joined
- Jun 12, 2019
- 7
I have a 1979 Johnson 115hp. I changed the impeller. Put new plugs in. I took it out for the first time yesterday. It would not idle very well. so I turned up the idle about 2 turns. after that I ran on the lake for about a hour. worked perfect. stopped to fish that is when every thing went bad. The boat will idle and I can run bring it up to 5k rpm, and 5k rmp in revers but it will not go over 2k rpm in forward motion full throttle. Ran like this for about a hour the stalled on me. Acted like the battery was dead. I pulled the plugs out and the motor turned right over. Put the plugs back in and the motor would barley turn. So I think the timing is off, but why would it only go 2k rmp in forward motion?
