1978 omc 140 3.0 engine (chevy 4cyl.)
big_daddy72
It has thrown a main bearing and am looking for a kit to rebuild the engine. Were is a good place to find what I need. I there a place to get a kit like they sell for auto engines?
Kainon
Re: 1978 omc 140 3.0 engine (chevy 4cyl.)
Yes, you can get engine main and conn-rod bearings from many marine engine rebuilder, maybe even this site. try google.com and type, Marine engines, hit search.
zbnutcase
Have never seen a rebuild kit for these engines; marine market so small I doubt they even exist, however, most good auto part stores can get what you need.
Kainon
big_daddy72
Do you know were to get the engine specs. The marine version is 3.0 but chevy didn't have a 3.0 liter in '78 they had a 2.5 liter (both same block) So I am assuming it has been bored among other things to make it a 3.0. If I had that info I could get the kit from an auto parts store.
spect8r
The only difference is the head that was used.
Ayuh,... The 3.0l has a Longer Stroke,+ Bigger Bore...
The 2.5l used in Chevy/ GM cars is NOT the same motor, nor the Same Block....
The 2.5l,+ the 3.0l used in boats, is only a Marine/ Industrial motor...
fat fanny
I believe that Napa has a wire aray of rebuid parts for the 4cyl. try thier marine catalog. My Napa gave me a catalog try your local store and they usually are more than helpfull.
hpdon
rebuilt my 3 litre over the winter 30th over speed pro flat top pistons , bought from summit racing felpro # 17000 head gasket rod bearings are your std. gm 350 mains are same .you might have to have your crank turned or polished. good luck
CobiaXL
Banned
I know its a lil late but Ive used rpmmachine dot com and am very pleased....
