1978 mercury v1750 choke to enrichener conversion
marb123
can i convert my 1978 v1750 black max from choke to enrichener would the carburetors bolt up from 80's black max?
Faztbullet
Re: 1978 mercury v1750 choke to enrichener conversion
Yep and yes as long as they are from a 150/175 2.0 liter engine.
marb123
Yes it is thank you can't wait to rebuild them and go fishing I am getting tierd of spraying pre mix into the carbs everytime I cold start the motor
dezmond
when you do spray, does it fire right up? what is the mixture your using in the spray bottle?
marb123
I use the fuel out of the gas tank on the boat which is 50:1 and she fires up and idles without advancing throttle but only when i spray pre mix into the carbs if i dont spray it in i drain both batteries before it starts and my Boston whaler revenge 21 flies with the merc on the back of it Thank you for help guys
