1978 mercury tilt and trim
cjo85
I have a tilt and trim and all it does is click. I just bought this boat and when i checked the fluid it was full of water. I cleaned it all out and replaced the fluid and still the same thing. is there any way to check and see if my trim motor is bad or is it in the wiring? I really want to get this fixed the cheapest way poss. I will put pics if I need to
monk-monk
Re: 1978 mercury tilt and trim
if you have a simple electrical tester...one that will "show" continuity, all you have to do is hook a negative wire to one of the small posts and then touch and hold a positive battery wire to the other small post...the solenoid (should) click...when it you hear it click in, put your continuity tester leads on the 2 big posts...if your meter reads continuity then your pump motor is bad...if it reads no continuity, then the solenoid is bad...even if the solenoid clicks, if you can't read continuity between the 2 big posts, then the solenoid is bad
