Basstrackerpro17
- Feb 14, 2012
- 8
I'm trying to wire up a new key switch to my 1978 Mercury 80hp motor. The motor has no spark at the plugs. I did some tests with an OHM meter. Looked at my engine harness wires and they were rotted. I replaced all 7 of the wires. Off the harness plug to the engine there are is big red and black wire for the battery. There are also 7 smaller different colored wires that run to the key switch and I think one of the 7 wires goes to the choke switch and one the the tach connector. That leaves five wires to wire to the key switch. I'm not sure where to connect the wires to the key switch because I'm not sure which one goes to the terminals marked ACC, GRD, MAG, BAT, and SOL. For example: Where does the red wire from the Rectifier hook to on the key switch? I have a drawing from maxrules.com but I'm not sure how to read the key switch diagram. Please help. Thanks.
