1978 Mercury 1150 Charging System
jeast
does this engine charge the battery while running or just keep the engine running. if it does charge does anyone know the voltage it should be charging at?
at the battery mine reads about 12.45 while it is running.
Chris1956
Honorary Supreme Mariner
Re: 1978 Mercury 1150 Charging System
That motor charges the battery while it's running. It doesn't charge too much at idle and about 6Amps at high RPM.
jimg984
check when idling and then check at higher rpm
gunnerb
i have a 77 1150 thunderbolt, does it charge the battery ?
Chris1956
please start a new thread. BTW - it should charge the battery.
