1978 Johnson 85hp outboard V4 carburetors
Arlan Jay
I have a 85HP V4 w/dual carbs. I just pulled the lower carb off and rebuilt it because there was fuel pouring out of the front of the carb. I still have the same problem even after the rebuild. What could be causing this?
Bosunsmate
Faulty carb needle/seat or float.
sometimes the float get sodden and never float to shut fuel off
Arlan Jay
Just rebuilt the carb today. New needle seat, new float. Was not sure about float adjustment process.
Bosunsmate
Pull it off, turn it upside down, if you can blow into it its got something wrong with needle/seat.
Float adjustment process is hard to explain, i basically make sure it shuts the valve off when its horizontal/parallel with carb body.
Arlan Jay
Thanks for paying attention Bosunsmate. I'll pull it off again tomorrow and see if I can figure something out. I'm pretty handy w/mechanics and thought that everything was going right and expected better results. :grumpy: In the mean time, I was reading that if the fuel pump was faulty, (too much pressure) It could send too much fuel to the carbs and they could not keep up. Also maybe there is a problem w/the fuel line from the tank to the motor. Maybe the check valves or something, I know that when I squeeze the primer bulb it begins to get hard but then the fuel just starts pouring from the carb.
Bosunsmate
sounds like the float and or valve in the carb to me.
what i do is i just tip it upside down and blow in the fuel inlet hole. That should not let my breath in.
I then adjust the float while still upside down so that its horizontal/parallell with carb body.
im no pro but thats always worked for me.
Fuel pump being too strong sounds like a fairy tale to me, unless a separate electric one is installed i dont think that could happen
If the check valves were bad you wouldnt get enough fuel to the carb
Bosunsmate
This
"I then adjust the float while still upside down so that its horizontal/parallell with carb body."
should have this added at the end
I then adjust the float while still upside down so that its horizontal/parallel with carb body- while the valve is still keep closed (ie no air being able to be blown in)
Bosunsmate
To make it close earlier(ie with a bit less fuel in carb), just adjust it so needle rises sooner. You will work out how that can be done once you look at it a while, its quite simple but effective.
check no dirt is in the seat too as that will stop the needle closing it off
goodluck
Arlan Jay
Ok, took the carb off and tore it apart and low-and-behold, I put the damn float in upside down. After telling myself 3 times to put the float in the right way I went and put it in wrong. So w/the carb rebuilt correctly and everything put back together she started up and ran very good for about 2 minutes and then stalled out and won't restart. I did however have the fuel pump off and tore apart prior to all this carb business and it clearly says that when you disassemble the fuel pump to throw away the diaphram and replace w/a new one. When I went to the parts store this am they did not have the fuel pump rebuild kit in stock so I will pick it up tomorrow am. Im hoping that w/the fuel pump rebuilt w/new parts that that solves my problems and I can get her running and go get some fish while the bay is full of them.
Bosunsmate
if you prime the fuel bilb manually to act as the fuel pump and keep the carbs full you can check if thats the problem before the pump arrives.
its correct that pulling it off commonly damages the pump.
you aint the first to install the float upside down
Arlan Jay
fuel pump rebuilt, engine won't start. plenty of spark and the carbs have fuel but engine won't start
Bosunsmate
Ground the HT leads to the block, then turn the engine over with the starter for about four seconds. remove all the plugs, check they all a wet with fuel, burn the fuel with a lighter, check it burns in a flash, ie check its not water contaminated.
If all plugs are wet and the fuel flashes and you are sure you have good spark then you will need to check timing and compression
Arlan Jay
Finally got my 1978 Johnson 85HP outboard on the water today. At first it would not rev up. Spent have the day going about 5mph w/the throttle leaver all the way down. As the day went on it seamed to gain some HP but in order for it to do so I had to key pressing the key in. I believe that activates a choke solenoid to make starting easier. By the end of the day we were going faster however it really seemed to run rough. Does anyone know if this was/is caused by the choke solenoid being out of adjustment? and how do I adjust this solenoid properly. I'm going boating on the lake in a couple of weeks and really need the boat to run right. PLEASE HELP
emdsapmgr
If the engine picks up rpm's when choked, it is running lean, or fuel-starved. When running the boat in the lake, have a friend constantly prime the fuel hose bulb. This will force extra fuel into the carb bowls. If it runs better, you have some type of fuel restriction or bad fuel pump. When you overhauled the carbs, did you pull all the jets out, visually inspect them and clean the carbs with an aerosol carb cleaner, like a Gumout type product?
