1978 johnson 70hp tilt with no pressure
tstobber0
I have a prestolite valve body I'm trying to rebuild. From my research, there's a piston that needs an oring changed but can't figure how to get it out and trying not to break it. There was snap rings on both sides that I removed. Also not sure about the check valve balls since they fell out when I took it apart. Any help is very appreciated!
tblshur
tstobber0 u might look at a parts diagram and see what you need :joyous:
tstobber0
link not working for some reason. But on any parts diagram it does't show the guts
tstobber0
take it nobody knows?? Thinking about pressing it out but like I said, really don't want to damage it. Hard to find old parts like this..
tstobber0
Was able to get it apart.... Had to put it back together, plug where lines would go and blow with compressed air. Hopefully this helps someone in the future!!
tstobber0
Still having issues here... I replaced the inner check valves with new ones(couldn't find the seal online) and same issue- NO PRESSURE! HELP!!
