Despite amazing wisdom to the contrary, I ordered new reeds. The service manual says an allowance of 0.010" is ok, but I had read elsewhere that if you see light through them they are bad. I figured I was already in there so... I had to order new intake gaskets anyway to replace the ones I took off.
Got a chance to test things with my DVA today. Took a minute to figure out how to make it work, but I got it. The service manual from 1978 says to use a neon test light, but I don't have one of those, so I was able to get a DVA reading for this engine from CDI Electronics. Here're the readings:
Stator- supposed to be 150V-400V, my reading was 295V, well within spec; it's brand new, so not surprising.
Timer base output- supposed to be 0.6V+
Sensor 1- 1.54V
Sensor 2- 2.7V
Sensor 3- 2.3V
These readings appear to be in spec. According to the CDI guide, "The trigger signal rides on top of the high voltage on these timer bases. Check stator DVA first. Then if timer base DVA is 0.6 - 2.5 V, the pack is faulty."
This is exactly what I did. Two of the readings fall within this guideline, one does not. I tested three times and got the same results.
It goes on further to say, "Check the DVA voltage on each Black/White wire to engine ground. You should have a reading of at least 150V or more (while connected to the pack). If the reading is low, disconnect the timer base wires from the pack and recheck the Black/White terminals ON THE PACK. If the voltage jumps up to an acceptable reading, the timer base may have a problem in the internal wiring (possibly a thin spot in the insulation on one wire)."
I did this, and got approximately 0.9V on each wire when connected. Then I disconnected them and got pretty much the same thing. This would lead me to believe that the timer base is ok, and that the power pack is dead or on its way.
Thoughts?
