1978 johnson 70 hp oil in carbs
tjohnson110772
ok i got this boat to finally turn over,but now when i crank it i notice there oil coming out of all 3 carbs.will not fire unless i put starting fluid in it then it fires right up.please help
StarTed
Don't think I can be of much help but I'll tag along.
I think the oil is probably normal if they're not firing. Check the spark and compression
tjohnson110772
there was alot of oil,i loosened the drain plug on the carbs and alot came out,boat has been sitting for a long time,could this all be normal and just needs to be cleaned
David Young
The float bowls are going to be full of gas and is normal. Maybe the floats need to be adjusted and the carbs are flooding. I would remove the carbs and rebuild them since the motor has been sitting for a long time.
boobie
Get some fresh fuel, pull the drain plugs out of the carbs and flush out the system before doing any thing else. Then try it.
