1978 johnson 55hp remove bearing carrier
john99
I cant get to carrier out of the lower unit, is their a tool to remove it and where can I get one??:confused:
john99
I tried That, this motor have three threaded 1/4 in bolts on the carrier, I used three 1/4 all thread with a puller, the nuts on the 3 all thread striped out???
Chinewalker
Did you remove the bolts holding the carrier in the unit? They are deep inside the hollow of the carrier. I believe there are three of them. Is this, by any chance, a salty?
Honorary Supreme Mariner
????-----You used 3 threaded rods to try and pull this out ?---You would remove the 3 bolts yes, but you can not use those 3 holes to pull it out.------Normally you would use a J-hook with a slide hammer on one of these.
john99
Thank you for your input, is this kind of tool available some where, maybe online???
You make it with a piece of threaded rod.----Bend one end into a hook.---Then use a slide hammer.
