1978 Johnson 55 HP where to get pistons
munrom
Hello i recently bought a 1979 vanguard trihull with a 78 55HP that has low to no compression on the top cylinder and the bottom cylinder has 150 psi i was just wonder if anyone knows where i can get pistons for this motor it seems like everywhere you go they are discontinued and no longer available, any help would be much appreciated!
Thank You
munrom
Tried eBay everything is for the newer 79 and up motor
Honorary Supreme Mariner
????------THey appear to be available from WISECO.------Might even have one in my cluttered workshop.
munrom
All my suppliers are out of the wiseco pistons and none on ebay ive been looking everywhere i found a guy that has a used motor with a good piston i might go grab and get a new set of rings to fit it
What is the difference between a 78 and 79 / 80 piston ?---Is it a hole drilled for a finger port ?
Tim Frank
Why do you need the piston?
Low compression can be a number of causes.
munrom
I pulled the head and the ring had let go and wrecked the piston and the cylinder head but i luckily found a couple power heads for 300 for the two that i can just swap into my base so i think thats what im going to do with it
