1978 Johnson 115, no spark on left bank
ib_fishn
No spark on left bank. moved powerpacks from left to right and still no spark on left bank. Brown/yellowbrown shows 597 ohms (which is within spec from what I've found on internet). Should I be looking at the stator or the timer base or somewhere else? Any help would be greatly appreciated!
jbuote
No expert, but...
​Are there screw terminals on your power packs?
​I guess I'm wondering if you can disconnect the blk/yellow wires from both power packs and see if you get spark on both banks..
​You've already swapped power packs and the problem stayed on the left, so if you can disconnect the kill circuit and you get spark, then there's a problem with the kill circuit for the left side..
​Not even sure if you can do that with yours, but figured I'd mention it..
For what it's worth...
ib_fishn
Not screw terminals but I bypassed the black yellow and still nothing.
Next I ran my brown/brown yellow from right side (good bank) to the left side and still no spark.
Hooked it all back up and now I have no spark on both sides.
I have a fluke meter so I measured max voltage of the brown/brown- yellows and I'm only hitting 60v for peak while cranking. Specs call for 150v; but now that's all I'm getting on the right bank as well, did I screw something else up or is the stator just shot?
So frustrated...
