FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
If the shift shaft and drive shaft are the same on each lower then yes. Count the splines on the drive shaft and compare. Same with length measurements.
If it's a 78, then it looks like it should fit. Both engines use the same shifter mechanism under the lower carb. You would want to make sure you get the shift rod set to the correct height. Make sure it is the same height as the (original) one you are replacing.
