Royglastron
Thread starter- Joined
- Apr 24, 2012
- 43
I have a 3-wire tilt motor. Can I connect direct to battery just to test or do I need to connect through the solenoid/direct box? Blue wire to positive on battery for up and back wire to negative on battery just to test for example. Trying to check if I have bad connection in direct box or solenoid or if it's the motor itself. Note: it's been years since the till/trim as been tested.
