1978 evinrude no spark
abreen89
I have a 1978 2 hp evinrude that im trying to get running. Currently there is no spark. I have obtained a manual and inspected everything as it has said they points all look good. The only problem i can find is maybe a bad connection at the spark plug boot, and the coil has a really rusted ground. Questions: would a rust ground for the coil cause no spark and ruin the coil? I dont have an ignition analyzer but i do have a multimeter can i just test the resistance of the coil? Any help would be much appreciated, i have an ignition tune up kit on its way just because they are cheap and probably wouldnt hurt.
Thanks
gm280
Re: 1978 evinrude no spark
Thanks
Oh yes a rusty coil connection can be a problem. And yes you can check the primary and secondary coil windings with your meter and verify they are not shorted together OR to ground and also that they read from input (primary) to ground for a resistance reading and spark plug boot to ground (secondary) winding for a higher meter resistance reading.
abreen89
okay i cleaned up all the ground and im running about 4 Ohms from the plug to the the ground. But i still cant get any spark! Should i just replace everything? Could there be another problem other than bad points and coil?
boobie
The only proper way to check a coil is with a coil load tester. I've seen coils with the proper ohm values and yet fail a load test.
gm280
NO don't go buying anything just yet. That won't be necessary or the proper way to fix and understand what truly is wrong. Now that you have the connections cleaned and can read a resistance on the coils, you need to see if the points are set properly. Set the points to .020" when the crank shaft lode is at it's highest (widest) point contacting the rubbing block of each point set. Then make sure that the points are not grounded out via a kill switch or an ignition switch. When the ignition switch is in the off position it shorts out the points thereby keeping the spark from firing the spark plugs. So verify that isn't your problem first. Then make sure the points are properly set. If those issues are correct you should get spark from the spark plugs. If you don't then you have coils either opened or shorted. But either condition means buying new coils at that time... You stated that you had 4 ohms on the coils, was that on the primary side or secondary side? The primary side is the side the points are connected to. The secondary side is the side the spark plug wire is connected to. You should have an ohm reading from both sides with the primary having a lower ohm reading then the secondary side... That verifies that the coils are at least not shorted or opened... They still can be bad, but we will see... Try those things and get back to us here...
abreen89
Great! Thanks for the reply. The Ohm reading was from the secondary side (plug wire). I will do what you said and get back to you.
