1978 evinrude 9.9 tiller handle shifting problems
jstan1984
i put my 9.9 evinrude in forward and it now goes in reverse even though its in forward position. neutral is neutral still and it wont even go into reverse position. i have no idea. it ran perfect for two years and worked fine all that day that it went bad. any ideas would be greatly appreciated. thanks
Joe Reeves
That problem is usually caused by someone attempting to shift into gear with the engine NOT running. This would cause one of the shift rods (upper or lower) to change position within the brass shift connector instead of having the groove of the rods aligned with the bolt hole of the shift connector.
Drop the lower unit to check that out.
jstan1984
thanks for the reply.is it right on top of the lower unit? if that is what happened whats my next step?
jstan1984
ok thanks joe ill try that this weekend and update after. i appreciate the advice
