1978 evinrude 85hp
Jad1982
How can I make More power or turn it into a 135 I think they have the same block.
Honorary Supreme Mariner
Sorry , they look the same but they are not the same displacement in cubic inches !!
emdsapmgr
The ports are smaller on an 85, cubic inches smaller-so none of the high compression heads will fit. No point in adding big carbs if the engine can't breathe well anyway.
jimmbo
What about the heads from a 1971 - 72 100hp? It too was a 92.6 block. I imagine the porting was different as well
oldboat1
^^^interesting (agree) -- that is, could be a hull issue. You may have a waterlogged hull, meaning the floatation under the floor. Pretty common in an old glass hull.
jimmbo
That might be jumping to conclusions that the OP is having performance issues. He just might want more power
oldboat1
No substitute for power. Do a google search on your hull. Rough guess is a 17 footer might be rated at max. 150hp or so, might do 60+ mph if motor and hull in good shape. (Should have a hp rating on the stern plate.)
