1978 evinrude 6hp engine startup help
Jrsa00
Hello all, I'm a long time viewer of this forum and first time poster.
I purchased a 1978 evinrude 6hp outboard motor from a farmer nearby as is.
Tried to start er up the other day and she fires up nicely. Problem is, the outboard starts and runs for a bit then shuts off after a few seconds. I was just wondering if anyone with the same outboard has come across this problem and if they know what the problem is/how to fix it. Any information helps!
Thanks!
Honorary Supreme Mariner
When was the last time he used it ?----------That was almost the last year that they made those wonderful motors.--------What happens when you squeze the primer bulb on the hose ?---------Remove that drain screw on the carburetor ( 7/16" wrench ) and do you see any green varnish on it ?----------Sounds like it needs the carburetor cleaned.---Also think about instal;ling a new impeller on the waterpump.
