1978 evinrude 35hp gauges
1955murman
hey i have a '78 evinrude 35hp and i"m wondering if it would be possible to hook up gauges like temp, tach, etc.
Thanks
billy4hp
Re: 1978 evinrude 35hp gauges
Thanks
What kind of gauges are you considering? You can always drill and tap for a coolant temperature sensor. A tachometer / hour-meter is easily added via a Tiny Tach www.tinytach.com. But as anything, the more you add the more likely it will fail down the road. Really good gauges are expensive so throwing a cheap Autometer gauge onto a boat just doesn't make sense IMHO... If your considering a voltmeter, be forwarned that most 70's outboards that charge a battery do so unregulated, so if you use an Automotive voltmeter it will more than likely have a red zone above 14 volts, unregulated marine charging systems usually charge @ over 15 volts at less than 10amps which is perfectly normal by design.
So if it were me, I'd pop on a Tiny Tach and be done with it...
