oldboat1
- Apr 3, 2002
- 9,612
...a puzzle.
look for five lead shots (according to the parts diagram for the carb) -- more, and a vent might be blocked (less, and the carb would be sucking too much air, or maybe leaking fuel).
The nozzle gasket is a thick one (usually cork) that fits over the bottom of the jet where it seats in the bowl. (In your opening post, you had referred to the top of the nozzle/h.s. jet -- don't know if that is significant.) The gasket goes on the bowl end (where your thumb is in the pic). One of the little openings in the nozzle appears to be peeking out just above your thumb. That's where blockages can occur -- not sure how many there are in that nozzle.
Probably all old news.
Let's see -- should be a plastic washer between the jam nut and the needle washers.
