1978 evinrude 150hp hasnt been started in years
kychiro
I bought a 78 evinrude 150 and im looking to get it back into running condition. Compression is ok. I plan on replacing the impeller, new lower unit lube, and I plan on rebuilding the carbs. How many rebuild kits do I need to buy to do this? First time tackling this type of job. Also, anyone with experience doing this, is there anything else I should consider replacing on an engine that's been sitting for a such a long time. thanks
boobie
Re: 1978 evinrude 150hp hasnt been started in years
3 carb kits, all new fuel lines and fuel filter. May want to get an OMC factory service manual also seeing it's your first job. What do you call good compression ??
Bosunsmate
New spark plugs
pump some two stoke oil petrol mix into it before cranking, slowly turn it by hand to get things lubed up
kychiro
all cylinders were around 100 +/- 8
I don't have much money in this project so far and im walking on egg shells afraid of uncovering something that will make it junk yard bound
theoldwizard1
That is a key point on older engines ! If the engine is equipped with any kind of automatic oiling system all vacuum and oil lines should also be replaced.
boobie
No auto oiling on this motor. Just 50:1.
kychiro
So 3 rebuild kits, should i buy the ones that include the floats? Will a yearly subscription to a service manual suffice?
emdsapmgr
Factory carb kits come with new floats. The compression is ok. After running it, recheck, it should be around 110. You may want to run a can of Bombardier Engine Tuner through the powerhead. Follow boobie's suggestion-none of the original factory fuel lines were made to handle today's ethanol fuels. The ethanol in the fuel will start to dissolve your original hoses. You will want to change all of them asap. Some of the fuel line hoses under the cowling are specials-factory made and heat treated to bend around tight corners. 319739 and 323546. These original part numbers supercede to newer 2014 part numbers. Normal fuel line will kink when bent tightly, causing fuel restrictions which can cause the engine to run lean.
theoldwizard1
A little Googling comes up with :
319739 -> 0332845
323546 -> 0333385
Make sure to use the Evinrude/Johnson fuel line zip ties 0320107 on your fuel lines.
