Let me start by saying that I'm new to outboards and dont have much experience with any kind of mechanical work.
I've owned this motor for almost a year and figured I would do some simple preventative maintenance (water pump, spark plugs, carb rebuild) as it's been running fine but the previous owner indicated they haven't done much to it except fresh gear lube once or twice a year.
When I started to remove the lower unit I immediately ran into trouble and after some prying I managed to get it off but the driveshaft slid out of the LU and is stuck up in the crankcase head (I think that's right?). After some research (tons of info on here) I decided that I would invert the whole outboard and its been getting baths of both PB blaster and ATF/Acetone once or twice a day for about the last 5 days. Most of that time has been spent hanging front the drive shaft. I've gone out the and given it a beating with a rubber mallet around where the LU bolts on as well as ratteled the drive shaft with a 20oz metal hammer. Nothing too aggressive as I'm really hoping that I can use the parts one in done. As far as I can tell it hasn't moved at all. I haven't used any heat yet because I only have access to a propane torch and I get the impression that won't provide enough heat especially if I'm hearing the top 6" of exposed shaft.
I HAVEN'T removed anything other than the LU so I'm wondering if I'm wasting my time treating it with penetrating oil....I know the drive shaft has an O ring up there. Should I be removing the power head from the exhaust housing(?) for better access the where the driveshaft is seized? Also what are the chances I'll be able to reuse the driveshaft and crankcase head? Will I need to remove the powerhead to attempt to clean out crankcase head once its separated anyways? I'm trying to avoid taking it to a shop as a shop rate will quickly overtake the value of the outboard anyways:s
Any advice is appreciated so thanks in advance.
I'm posting from my phone and do have paragraphs but they don't seem to show up in the preview (just looks like one big paragraph) so I apologize for that.
